Distributor Installation Help
Old Aug 4, 2012 | 10:38 PM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Distributor Installation Help
After reinstalling my intake manifold, I went to install the distributor but lost the mark that I had it set at. So I followed the procedure to TDC but now every time that I go to install the distributor it is either before the 6 mark or after it.
I rotate the oil shaft just a hair and it seems like it throws it off completely. I tried adjusting with a magnetic screw driver and that was a mistake. Finally found a tool to use and I turn it just ever so slightly and it throws it off completely.
Is it possible that when I am putting the distributor in that its rotating the oil shaft on its own?
Old Aug 5, 2012 | 02:44 PM
step66's Avatar
Search this site! The 6 refers to a six cylinder distributor not #1 TDC! Many instructions here!
Old Aug 5, 2012 | 04:11 PM
aa21830's Avatar
aa21830 is on a distinguished road
I've found that i usually have to "lead" the rotor a little to get it to set right on the 6. That may require some trial and error with the rotor gear position to get it right.
Old Aug 5, 2012 | 04:28 PM
This link explains how to install the distributor: https://blazerforum.com/forum/tech-a...-timing-24373/
Old Aug 5, 2012 | 07:59 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
wrong. The "6" denotes where the rotor should point when #1 is at TDC on a 4.3L V6.
racsan
Feb 10, 2013 08:01 PM
crazzydrdrbig
Mar 23, 2008 09:45 PM
rdhack
Feb 8, 2008 06:30 PM
LunchBox
Dec 27, 2007 09:20 PM
strubby
Oct 17, 2006 09:07 PM
