Distributor Reinstall
Old Jul 21, 2013 | 05:19 PM
96 chevyblazer's Avatar
96 chevyblazer is on a distinguished road
Default Distributor Reinstall
Hi all,
I have 96 blazer and I removed the distributor to check the drive gear but did not mark when removing.So I followed Kyle's "edi engine timing" guide to reinstall the distributor.All went well until I started the truck. I have a really bad misfire. Just wondering what I may have done wrong.
Old Jul 21, 2013 | 07:05 PM
abig84's Avatar
crossed wires maybe?
Old Jul 21, 2013 | 07:23 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Any codes?
Old Jul 21, 2013 | 07:35 PM
Double checked wires none appear to be crossed. I have had a p0300 code for some time that is why I pulled the distributor to check the drive gear.Don't Have a scan tool and have not been able to drive it to have cel check to see if it throwing a new code.This misfire is worst than before I pulled the distributor. I had a very slight misfire at idle only. Truck ran great other than that. No misfires at higher rpm's
Old Jul 21, 2013 | 07:40 PM
4X4GS10B's Avatar
When you started it did it start easy,or did it take longer that normal, and was difficult to start?
Old Jul 21, 2013 | 07:43 PM
it started fine no problems at all
Old Jul 21, 2013 | 08:38 PM
4X4GS10B's Avatar
Check all electrical connections(at distributor),I'd also suggest making sure all plug wires are seated on distributor cap and plugs. Cap on straight(screwed down snug)
(Kiss) keep it simple stupid. That's my philosophy.
Old Jul 22, 2013 | 07:10 AM
abig84's Avatar
it might be unrelated. ive installed distributors wrong before on these trucks and the truck will throw a code almost instantly. also the last time i did it the truck actually ran and idled fine but when you gave it gas it had like zero power
Old Jul 22, 2013 | 07:53 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
try moving it a tooth at a time till its right. clearly it isnt on there right. You have to align the oil pump drive each time
Old Jul 22, 2013 | 08:22 AM
Checked all electrical connections at distributor. Checked all plug wires. Cap on tight. Andrew do I need to align timing marks each time I pull the distributor to move it a tooth at a time?
