distributor removal
Some details about your truck would help.
I use a ratcheting wrench with a slight offset. The TBI and SCFI motors are fairly straight forward. On the SCFI motors, I remove the ICM and coil to get better access. The CPI motor can be a challenge though. Remove anything that you can from the area around the distributor to allow for better access. Hopefully you are good at working without being able to see what you are doing.
jprout
Dec 6, 2011 06:03 AM
rnjohnson
Jan 28, 2006 09:57 PM
