distributor removal
Old Jan 8, 2009 | 06:45 PM
cruzin94's Avatar
cruzin94 is an unknown quantity at this point
Default distributor removal
what is the best way to remove the bolt that holds the distributor in i tried a couple things but that bolt is in just a weird spot any suggestions would be great
Old Jan 8, 2009 | 07:02 PM
Default RE: distributor removal
Some details about your truck would help.
I use a ratcheting wrench with a slight offset. The TBI and SCFI motors are fairly straight forward. On the SCFI motors, I remove the ICM and coil to get better access. The CPI motor can be a challenge though. Remove anything that you can from the area around the distributor to allow for better access. Hopefully you are good at working without being able to see what you are doing.
Old Jan 8, 2009 | 08:12 PM
cruzin94's Avatar
i have a 96 blazer ls im not sure what motor i have i just bought the truck a week ago so i dont no much about these
Old Jan 8, 2009 | 08:14 PM
A 96 is the SCFI motor.
Old Jan 8, 2009 | 08:22 PM
cruzin94's Avatar
thanks for the info just one more ? what size is the bolt that holds down the distributor
Old Jan 9, 2009 | 06:13 AM
Funkydrummer57's Avatar
Funkydrummer57 is an unknown quantity at this point
I was just working with this on Wednesday and I didn't have too much trouble using a crows foot wrench on a CPI motor.
Not too bad to access it from the passanger side of the engine.
Old Jan 10, 2009 | 06:07 PM
cruzin94's Avatar
yea i just learned of these crow feet so i have to pick one up i i think it will make it alot easier to get to
jprout
Dec 6, 2011 06:03 AM
maepis
Jul 25, 2011 07:29 AM
vatoDETH
Aug 22, 2010 04:41 PM
ShaneInsane
Sep 6, 2007 05:02 PM
rnjohnson
Jan 28, 2006 09:57 PM
