Do I have a stock 350?
Old Feb 27, 2010 | 02:19 PM
jayfire's Avatar
jayfire is on a distinguished road
Default Do I have a stock 350?
I have an 1985 K5 blazer. I am in the process of changing the valve cover gaskets and noticed the valve covers say GM Goodrich 350 on them and it has an Edelbrock carb. Is this the stock 350 it came with or is this a crate engine. After taking the valve covers off, the heads look pretty clean. Can someone help. Thanks
Old Feb 27, 2010 | 03:45 PM
Unless someone swapped over the valve covers onto your original engine, it likely is a replacement motor.
Old Feb 27, 2010 | 11:33 PM
jayfire's Avatar
Are there any numbers on the engine I could check to see if it is a crate engine? Did stock 350's come with the Edelbrock carb? Thanks
Old Feb 28, 2010 | 12:09 AM
1oldK5's Avatar
1oldK5 is on a distinguished road
Stock 350s would have come with a Rochester Quadra-Jet, more then likely somebody changed that as well to the Edelbrock just for a better quality.
Old Feb 28, 2010 | 03:37 AM
04CVLXsport's Avatar
04CVLXsport is on a distinguished road
There is a pad on the passenger side of the engine just in front of the head, Might have to remove the alt to see it good, but there should be some numbers and letters on that, Let me know what they are .
Old Feb 28, 2010 | 05:08 PM
jayfire's Avatar
I did some researching on the head #'s and found that it is a crate motor. Goodrich Gen 1 base 350 from 1990-up, and someone must have put the Edelbrock quadrajet on it as well when swapped because they do not make those carbs anymore. Thanks for the help.
tech180
Feb 2, 2013 10:23 AM
slowsinglecam
Jun 14, 2012 10:12 PM
Spectreblazer
Feb 13, 2010 04:59 PM
huntersblaze
Tires and Wheels
Jun 20, 2009 04:39 PM
y2kblazer
Dec 2, 2006 08:54 PM
