drive and reverse are switched!!
hey everyone! im looking into buying a 94 s10 blazer and the guy told me drive and reverse on the column shifter are reversed and the truck doesnt go into park. i dont know if a previous owner put a shifter linkage in and messed it up or the transmission is messed up. and for park youd have to put it in neutral and pull the ebrake. i dont know if thats transmission problems either. any help would be great thanks!!
Remove the rod going to this bracket then Unbolt the shift arm from the transmission and flip it 180 degrees. Then reinstall the shifter rod. Has gotten installed upside down at some point. Good luck.
Attachment 36357
Attachment 36357
adc
02-19-2016 08:32 AM
Tinted
11-30-2011 02:07 PM
wirespider01
11-13-2011 04:12 PM
radiokid
12-28-2010 09:00 PM
