"eating" distributor gears...
Old Jan 29, 2015 | 05:48 PM
guitar134's Avatar
guitar134 is on a distinguished road
As i recall when i put the second one in, my local gm tech had told me about the +/- 2* spec and when i checked it was sitting at +1*
how do you mean "mod" drill the hole out for side to side movement or drill it so that it can be turned like an older style distributor?
Old Jan 29, 2015 | 06:03 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Grind the tabs off the bracket, or u can just use an sbc holdown , this will allow the dist to be fully adjustable like the old school ones......
Old Jan 29, 2015 | 08:55 PM
Nice job explaining it Jeff, you paid attention in class
Old Jan 30, 2015 | 08:37 PM
07nhbpsi's Avatar
U taught me well!!!! we need to hang out again........ I need to learn more
Old Jan 31, 2015 | 12:02 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
One thought, when you install the distributor is there any side to side movement at all? if there is then there may be some wear on the intake manifold and this is letting the distributor shaft "walk" from side to side. This is the only other thing i can think of that would destroy the gear. There are only so many things that could cause this and we have pretty much covered them I believe.
Old Jan 31, 2015 | 03:05 PM
The ID for the distributor in the intake manifold is larger than the OD of the distributor, so it will move around, perfectly normal. This is what allows camshaft retard to be adjusted, and also what causes the gear to wear out if it's not adjusted correctly.
Old Feb 1, 2015 | 10:45 AM
Gregg64's Avatar
That would make sense Capt. I knew that the only way this could happen is if the dist. was not set properly and it sounds like there is very little allowance in this particular system.
James1965
Jan 16, 2012 11:32 AM
95BlackGA
Nov 17, 2011 10:55 PM
megaroos_00
May 4, 2010 06:39 PM
nonblazing4x4
25
May 28, 2009 05:00 PM
EuroGoldLS
Street N Strip
78
Apr 11, 2008 04:06 PM
