EGR?
Old Dec 18, 2007 | 03:51 PM
gohan69's Avatar
gohan69 is an unknown quantity at this point
Default EGR?
Does anyone have pics of where the egr valve is and how to clean anyhting would be a great help
thanks
Old Dec 18, 2007 | 05:11 PM
JustBlaze99's Avatar
JustBlaze99 is an unknown quantity at this point
Default RE: EGR?
what year is your blazer? i know the new 4.3 is right in front and you can just take carb cleaner take the egr off and and clean it with that
Old Dec 18, 2007 | 05:34 PM
rriddle3's Avatar
Default RE: EGR?
I believe you have an '01 4wd, don't you? The EGR valve is located at the front of the engineto the right ofthe radiatorhose connection.
[IMG]local://upfiles/4800/FDB5E73DB17749209409DA0F9DABDEDB.gif[/IMG]
Disconnect the harness connector and remove the bolts holding the valve to the engine, remove the valve and the gasket.
[ol]Depress the pintle several times using a pencil eraser or other suitable soft instrument. The pintle should move in and out smoothly. Replace the valve if the valve exhibits tendencies to stick.
Try to rotate the EGR valve electrical connector housing. Repeat for the coil housing. Replace the valve if the valve exhibits any looseness.
Inspect the EGR valve pintle and seat for deposits. Use a cloth or other suitable soft device to remove the deposits. Remove all loose particles. Replace the valve if the deposits are such that the pintle to base interface cannot be cleaned adequately to allow the pintle to seal against the seat. Damage to the powdered metal EGR valve base occurs if cleaned with solvents, sharp tools, wire brush or wheel, or sand blasting. Cleaning by these methods is not recommended. [/ol]
Installation is the reverse, use a new gasket.
Old Dec 24, 2007 | 03:51 PM
gohan69's Avatar
Default RE: EGR?
Thanks for the input ill try and let you guys know
BlaziNator
Oct 26, 2009 03:43 PM
yzf125
16
Jun 18, 2007 02:47 PM
blazingsadle
Feb 4, 2006 06:14 PM
khalid_20879
Dec 28, 2005 08:43 PM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
