EGR Valve???
Old Apr 2, 2009 | 07:06 PM
TomSawyer's Avatar
TomSawyer is on a distinguished road
I'm not sure what you said there swartlkk. Explain further please.
Old Apr 2, 2009 | 08:20 PM
Can you be more specific? What did you not understand? Have you tried searching for any of the terms I have used that have no meaning to you?
Old Apr 3, 2009 | 04:21 PM
bjsx8f's Avatar
bjsx8f is an unknown quantity at this point
i have yet to get the codes ran, but another thing that might help narrow this down. If I have a half a tank of gas or been driving for a while it usually doesnt spudder much... It gradually got worse in time it wasnt an all of a sudden problem....
Old Apr 5, 2009 | 08:01 PM
1blkblazer422's Avatar
1blkblazer422 is an unknown quantity at this point
I cleaned the EGR today and got the new gasket with the screen in it. Also replaced fuel filter and cleaned MAF sensor. Same result as before with the rough idle and bucking under TCC lockup. I then sprayed under my hood with water and the engine almost stalled and idled horrible. I am now thinking cracked wire so I am going to replace my wires and cap and rotor. Ill keep you posted.
Old Apr 6, 2009 | 01:03 AM
bjsx8f's Avatar
or possibly intake leak.... that was another thought in my mind about mine
Old Apr 6, 2009 | 06:43 AM
So your problem varies with fuel tank level? If that is the case, then it has to be a fuel supply issue. Have you monitored the fuel pressure while driving the truck?
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
BlaziNator
Oct 26, 2009 03:43 PM
yzf125
16
Jun 18, 2007 02:47 PM
khalid_20879
Mar 14, 2006 04:23 AM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
