EGR Valve question.
Old Dec 12, 2009 | 10:57 AM
S10Blazer's Avatar
S10Blazer is an unknown quantity at this point
Default EGR Valve question.
Hello, I am going to have my egr valve replaced with a new one, and I just wanted to know if the part of the engine where the egr bolts on to has to be cleaned, or can it just be bolted on with the new gasket?
Also, the carb cleaner that I might buy if needed says it is safe for Oxygen sensors and catalytic converters. If I do need to clean the part of the engine where the egr goes, will this be ok?
Old Dec 12, 2009 | 10:59 AM
I like to clean out the supply tube so that chunks do not plug up the new valve. Also, get the gasket with the integrated screen.
Old Dec 12, 2009 | 11:05 AM
S10Blazer's Avatar
Perfect!!! I already have a Tomco gasket that has the screen you're talking about. Now I just gotta buy the cleaner. Thanks a lot!!!
Tuna
24
Mar 12, 2015 11:42 AM
Kyle Wood
Feb 22, 2012 09:14 AM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
deegan26
Jan 8, 2010 07:06 AM
dobbist
Engine & Internal
May 1, 2005 04:02 AM
