encoder motor
Old Dec 27, 2009 | 08:57 PM
acslip's Avatar
acslip is on a distinguished road
Default encoder motor
I have a 94 s-10 blazer, I'm having issues with my 4 wheel drive, sometimes the lights on the 4 high and 4 low come on, sometimes they don't, sometimes the 4 wheel engages, sometimes is does not. I can hear the transfer case move and then is does not, the actuator under the battery cable was pulling in and out, but now there is no vacuum. I check the codes and I have a code 2 which is "encoder motor".
My question is how reliable are the codes? I do not want to go and buy the encoder motor and this end up not being the issue.
Any help from anyone would be appreciated.
Thanks
acslip
Old Dec 27, 2009 | 09:02 PM
If you are not sure, test. error_401 wrote a pretty good article in the Tech Article (DIY) section on the NV233 transfer case electronics.
Old Dec 27, 2009 | 10:16 PM
acslip's Avatar
If I'm getting a # 2 code, does this eliminate the tccm being bad, as if this was bad I would not get any codes correct?
acslip
Old Dec 28, 2009 | 06:13 AM
There is plenty of documentation at your finger tips. Read up and then let us know if you still have questions.
Old Dec 28, 2009 | 09:24 AM
acslip's Avatar
I have been reading up, I been through most of the threads on this forum. I been all through the internet. And I'm still confused as ever. Before I start buying all kinds of parts I would like to know which is bad the tccm or the encoder motor. from everything I read it sounds as everyone is a confused as I am.
acslip
Old Dec 28, 2009 | 12:25 PM
Do you know how to work a multimeter? If so, then test away. You can quite easily verify that the encoder is at fault by simply testing it given the information in the aforementioned thread by error_401.
Old Dec 28, 2009 | 05:54 PM
acslip's Avatar
Yes I know how to use a multimeter, I pulled the tccm today and tested and I'm getting voltage there on several pins, ~11.8 to 11.9 volts. So I believe this is good. Today the 4 wheel is working just fine, so this is an issue that comes and goes. I have not tested the encoder yet.
acslip
One thing I forgot to mention, I'm not getting the code 2 anymore which is the encoder, but now I'm getting a code 1 which is RAM standby power fault. The book says open connection or short in the tccm. All the wires looked good and the connection looked good as well. Could the short be in the tccm it self?
acslip
Last edited by swartlkk; Dec 28, 2009 at 07:27 PM. Reason: Combining Consecutive Posts - Please use the EDIT feature if another member has yet to respond. Consecutive posting is against forum rules.
Old Dec 29, 2009 | 02:00 AM
jacobcnc's Avatar
jacobcnc is on a distinguished road
You will get code 1 any time you unhook the tccm
Old Dec 30, 2009 | 06:49 PM
acslip's Avatar
so if the four wheel works and then does not and i'm not getting the code 2 anymore, would it be same to say that my encode motor is going bad and not my tccm?
Old Dec 30, 2009 | 07:03 PM
Sounds more like you have a connection problem than a component problem.
