encoder motor
I have a 94 s-10 blazer, I'm having issues with my 4 wheel drive, sometimes the lights on the 4 high and 4 low come on, sometimes they don't, sometimes the 4 wheel engages, sometimes is does not. I can hear the transfer case move and then is does not, the actuator under the battery cable was pulling in and out, but now there is no vacuum. I check the codes and I have a code 2 which is "encoder motor".
My question is how reliable are the codes? I do not want to go and buy the encoder motor and this end up not being the issue.
Any help from anyone would be appreciated.
Thanks
acslip
Thanks
acslip
I have been reading up, I been through most of the threads on this forum. I been all through the internet. And I'm still confused as ever. Before I start buying all kinds of parts I would like to know which is bad the tccm or the encoder motor. from everything I read it sounds as everyone is a confused as I am.
acslip
acslip
Do you know how to work a multimeter? If so, then test away. You can quite easily verify that the encoder is at fault by simply testing it given the information in the aforementioned thread by error_401.
Yes I know how to use a multimeter, I pulled the tccm today and tested and I'm getting voltage there on several pins, ~11.8 to 11.9 volts. So I believe this is good. Today the 4 wheel is working just fine, so this is an issue that comes and goes. I have not tested the encoder yet.
acslip
One thing I forgot to mention, I'm not getting the code 2 anymore which is the encoder, but now I'm getting a code 1 which is RAM standby power fault. The book says open connection or short in the tccm. All the wires looked good and the connection looked good as well. Could the short be in the tccm it self?
acslip
acslip
acslip
Last edited by swartlkk; Dec 28, 2009 at 07:27 PM. Reason: Combining Consecutive Posts - Please use the EDIT feature if another member has yet to respond. Consecutive posting is against forum rules.
