engine barely runs and runs ruch
Old Jun 18, 2013 | 08:57 PM
fnbutch's Avatar
fnbutch is an unknown quantity at this point
Default engine barely runs and runs ruch
I was driving my 4.3 l CPI vin (w) to work one day and the water pump decides to go out causing the engine to overheat without me knowing until it was to hot. Before I could shut the engine off it actually died. and the engine has ran like crud ever since ( have to depress accelerator to star, idles real bad like missfiring and exhaust smells real rich). I noticed it runs rich and there seems to be gas getting into the oil somehow, however i had this problem before and it was the fuel spider which i replaced brand new and was running great for 2 years prior to this incident. I pulled the upper intake and it seems that there is gas in the plenum again as well. I had also wondered if the heat might have caused the head gasket to blow. Well i checked compression on all six cylinders and i got 147 -151 on all 6. So i went ahead and replaced water pump and let it run to see if i could get it back operational temp but before it got there i noticed a lot of what smelled like water vapor coming from behind the engine?!?! Could this be a head gasket? there are no visible coolant leaks! Does anyone know if this could be a head gasket problem. or possibly warped head??
Old Jun 25, 2013 | 12:08 AM
go-part's Avatar
Former Sponsor
go-part is on a distinguished road
Do you see any white smoke from the exhaust? Does the coolant level seem to keep lowering?
Have you tested your maf sensor or IAC?
Car Engine Damage From Overheating | eHow
corradovrt
Nov 19, 2013 06:39 PM
Blazer88
Sep 23, 2012 08:32 PM
xul
Aug 14, 2011 04:57 PM
couve chevy
Jun 15, 2010 07:51 AM
Alex01tib
Oct 12, 2006 04:47 PM
