Engine Code p0573 & p0758
Old Dec 16, 2013 | 06:20 PM
99TrailblazerConway's Avatar
99TrailblazerConway is on a distinguished road
Default Engine Code p0573 & p0758
First i would like to introduce myself to the forum. I am mark and i own a 99 blazer with the trailblazer option. Ive always loved blazers and im glad to finally own one. I want to be an active member of this forum with me now owning a blazer. I will keep this post going even after figuring it all out so it can help other people that have the same problem as ive had.
Heres the start of it. I realize it feels like im stuck in a high gear so i go and get my check engine light checked for the codes and have p0753 and p0758. Solenoid A & B Electrical..
Heres what ive done so far.
1st checked my clster fuse for power i have 12v
Dropped my trans pan and pulled my solenoids off and hooked up a ohm reader they are reading 16ohms pulled out of my valve body.
Hooked up a voltage meter to my solenoid plug read 11v for both A&B.
I called a trans shop and they said check the ground if they are grounded then its either the solenoids or the computer.
I do not understand how to check the ground. I by no means is master mechanic but a common diyer.
I would like some advice and a push to tell me what to do next. I will keep posted and post after i figured it out.
I appreciate all the input and look forward to becoming an active member of this forum
Thank You
Mark
Old Dec 16, 2013 | 06:55 PM
Sorry about the title. Engine code p0753 not p0573
Old Dec 16, 2013 | 07:18 PM
A push in the right direction would be great. I got the blazer on friday drove it home codes came up while pulling out of car lot. Drove it home and parked it. I want to drive it..
Old Dec 16, 2013 | 08:45 PM
Should i just replace both solenoids and put my pan back and hope it fixes it? Should i continue to look for other reasons as why the engine codes are there?
BigTodd
Oct 15, 2012 05:39 PM
my96willkillu
Jan 26, 2010 09:25 AM
mav06
Jun 1, 2009 04:10 PM
loppy crimp
Oct 13, 2008 04:17 PM
krazeygirl1980
Sep 29, 2008 08:57 PM
