Engine cranks but no start after overheating!!! Need help!
Old Feb 22, 2022 | 08:31 PM
thekid.alex's Avatar
thekid.alex is on a distinguished road
Default Engine cranks but no start after overheating!!! Need help!
So the inevitable happened today. While i was driving one of my heater core hoses blew up and my truck started overheating. Luckily i was very close to home and made it into my driveway before the temp gauge could go over 230 F. Total time it spent overheating was maybe 1-2 minutes. I replaced the hose and topped off the antifreeze and when i tried to start it, it only cranks. I checked for fuel and spark and i also checked my oil to make sure i don't have the forbidden milkshake. It all seems in check. I can't figure out what's wrong with it. Tomorrow i'm going to do a compression test. Does anyone have any tips or leads i could look into? Thanks. I have a 2001 Blazer 4d 4wd.
Old Feb 22, 2022 | 10:42 PM
GeorgeLG's Avatar
Check:
Fuel Pressure per the sticky
Spark at 2 different cylinders
Compression
Fuel injector pulses
Could be engine damage and bad compression, water damage from the spewing hose, heat damage.
George
Old Feb 23, 2022 | 09:06 AM
Check that your distributor cap isn't wet inside from the spray of coolant.
BlackBlazerCricket
Jun 4, 2014 12:40 PM
schraml
Feb 16, 2010 01:19 PM
Smiller94
Sep 2, 2009 08:05 PM
78Special
Jan 5, 2008 07:20 PM
96Ls4Dr
17
Apr 9, 2007 10:10 AM
