Engine hoist attachment
Old Jun 21, 2009 | 10:05 PM
bbell's Avatar
bbell is on a distinguished road
Default Engine hoist attachment
Been doing some research and getting ready to do a engine swap. I was wondering can anybody tell me the best attachment method to use when pulling a 1996 4.3 vortec vin w engine? I trying to figure out the best way to attach the engine hoist to the engine. Thanks
Old Jun 21, 2009 | 10:09 PM
I usually pull the accessory drive brackets off the front of the motor (driver side at least) and then use one of the tapped holes in the front and back of the heads on opposite banks with two short pieces of steel I made up close to 20 years ago. The pieces are about 4" long, 2" wide, 1/4" thick straps with a 1/2" hole drilled on either end. They have pulled in excess of 20 motors!
Old Jun 22, 2009 | 12:38 AM
bandidolenny's Avatar
I have used the same attachment points but instead ran a grade 8 bolt with a washer through the chain links.
Old Jun 22, 2009 | 06:21 PM
bbell's Avatar
Thanks guys,
I was thinking of making a plate that attaches where the A/C compress was, something like a four bolt plate with an eye hook in the middle. I believe that this would probably work for the drivers side. I just couldn't think about the pass side attachment. I think that I will give the iron straps a try.
Thanks again.
Old Jun 22, 2009 | 09:14 PM
I like the straps because I have run into firewall clearance before using a longer bolt through a chain. My straps have kind of taken a set with a little bend in them from use. They still work great though! I'll be pulling the motor from my 1990 Suburban donor truck soon.
wrxin
Oct 15, 2013 12:09 PM
xtr1c0
31
Dec 28, 2011 01:16 PM
metalhead
Nov 8, 2011 07:05 AM
jonnycakes
Mar 11, 2010 02:32 PM
