Engine lurch and cuts off - '89 Jimmy
Old Feb 6, 2018 | 02:11 PM
cadkins5's Avatar
cadkins5 is on a distinguished road
Default Engine lurch and cuts off - '89 Jimmy
Recently acquired the 1989 Jimmy. A few times (twice today) when I was coming to a stop the engine died. It did restart but not as quickly as a normal start. It will also "lurch" on occasion when stopped and a few times the Check Engine Light has come on right after a lurch. Because of it being an 89, box stores can't connect and check for a code so I know I need to go to a mechanic for the engine light issue to see what it means, but any suggestions on what could cause it to just start cutting off?
Thanks,
Old Feb 7, 2018 | 04:07 PM
Snap-Off's Avatar
Snap-Off is on a distinguished road
I don't think GM has a part# for this tool just yet , but it is generally referred to as a Paperclip....Next time your CEL\SES light is lit, follow these instructions:
https://ck5.com/forums/threads/tbi-t...-codes.240425/
Old Feb 7, 2018 | 04:31 PM
Snap-Off's Avatar
In terms of the symptoms, it could be a wide range of things as we all know. But 2 things come to mind and are relatively easy. Clogged EGR and\or a stuck IAC. There's an EGR cleaning process around here somewhere...
Old Feb 8, 2018 | 06:17 AM
cadkins5's Avatar
Thought for sure you were pulling my “newby” leg, but based on the link you shared it looks like a Paperclip is the way to go. Thanks for the tip.
Old Feb 8, 2018 | 06:44 AM
Snap-Off's Avatar
lol , used to use that trick on my 89 IROC , which in itself was a never ending project..It would act like your Jimmy whenever the EGR got crudded up..
D_Beezy18
Nov 21, 2011 10:59 PM
lovetoblaze
Mar 31, 2009 09:01 AM
ctberry78
Mar 24, 2009 08:33 AM
Roma
Jun 18, 2007 03:04 AM
swartlkk
Nov 15, 2006 01:46 PM
