Engine lurch and cuts off - '89 Jimmy
Recently acquired the 1989 Jimmy. A few times (twice today) when I was coming to a stop the engine died. It did restart but not as quickly as a normal start. It will also "lurch" on occasion when stopped and a few times the Check Engine Light has come on right after a lurch. Because of it being an 89, box stores can't connect and check for a code so I know I need to go to a mechanic for the engine light issue to see what it means, but any suggestions on what could cause it to just start cutting off?
Thanks,
Thanks,
I don't think GM has a part# for this tool just yet , but it is generally referred to as a Paperclip....Next time your CEL\SES light is lit, follow these instructions:
https://ck5.com/forums/threads/tbi-t...-codes.240425/
In terms of the symptoms, it could be a wide range of things as we all know. But 2 things come to mind and are relatively easy. Clogged EGR and\or a stuck IAC. There's an EGR cleaning process around here somewhere...
lovetoblaze
Mar 31, 2009 09:01 AM
Roma
Jun 18, 2007 03:04 AM
