Engine is making a whining noise when the car is off. 2000 Chevy Blazer
Old Oct 31, 2023 | 04:52 PM
Logdogs99's Avatar
Logdogs99 is on a distinguished road
Default Engine is making a whining noise when the car is off. 2000 Chevy Blazer
When I turned off the ignition of my 2000 chevy blazer there is a whining noise coming from the front of the engine. I went inside and about an hour later the noise was still there. I’m not sure what the reason is, but i’ve read online something about a fuel pump, not sure if that has to do with it.
Old Oct 31, 2023 | 07:00 PM
The fuel pump is in the fuel tank. Can you pinpoint from where the sound is originating?
Old Oct 31, 2023 | 07:04 PM
Logdogs99's Avatar
The noise is at the front of the engine; if needed i can provide a picture for you. right by the belts
Old Oct 31, 2023 | 07:38 PM
Perhaps it is cooling system leak and what you are hearing is the leak?
The fuel comes up from the back of the engine onto the top of it. So therefore what you are hearing is unlikely fuel related.
Can you describe the sound? Does it change over time? Does it die off eventually? Is it present only when the coolant is hot?
Old Oct 31, 2023 | 09:00 PM
Logdogs99's Avatar
i have a video of it, is there anyway i can contact you and show the video? the video is to big of a limit. it’s like a squealing/whining noise. you can hear it from the front bumper.
Old Oct 31, 2023 | 09:01 PM
Logdogs99's Avatar
the sound is consistent, doesn’t stop and keeps the same pitch. it doesn’t die down
Old Oct 31, 2023 | 09:59 PM
That is weird. I don't know if I can help. The best advice would be to try to locate it. Auto parts stores sell stethoscopes for locating engine sounds. That is what I would try.
Perhaps someone else has an idea.
As for posting your video, there must be some way you can reduce its file size. Then perhaps others on the forum might be able to identify it.
Old Oct 31, 2023 | 10:07 PM
AJBert's Avatar
The only electrical motor up in that area is the air injection pump. See if you can find the fuse for it and pull it. If the noise stops then you have found the source. As for the cause? I haven't a clue.
Old Nov 2, 2023 | 11:28 AM
GeorgeLG's Avatar
What AJBert said.
To follow up on Christines suggestion make a listening devive out of a long screwdriver or the tire iron. Cup the end with your hand and hold that up against your ear. Then start touching all the stuff in that area until it gets louder. Engine off of course.
George
SilverBear
Jan 31, 2021 03:32 AM
BFischer
Nov 29, 2013 06:47 PM
ssmith0386
Nov 17, 2013 08:02 AM
ronkrolock
16
Mar 4, 2010 09:17 PM
A_&_J_Hernandez
Jan 27, 2010 11:26 PM
