engine mount??
Waiting for my suppplier to here from his supplier, so I thought id ask you guys.
Will a mount for a 2001 blazer/jimmy 4X4 work on a 2002 blazer/jimmy 4X4??
Been wondering why my K&N intake keeps comming off.Damengine was lifting about 3-4" up on the drivers side.
The AutoZone website shows them to be the same part number.
Get the Energy Suspension mounts, instead of factory replacements... They'll last a whole lot longer.... Actually, from what I've heard, you won't break them 4x4ing ![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
Synergy Offroad carries them.
So the one from Energy Suspension thats listed for 2001 Should work. hmmm. I think I may get that one.
If you offroad at all, they're a good investment... I'm picking up a set + transmission mount, soon as I can afford it, before mine break, lol.
Oh, ill be off road alot this summer. Well, between car shows with the lude anyways
![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
Then you're definitely going to want the Energy Suspension mounts ![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
Especially if you use 4LO
#%#$in engine mount. Almost 3 hours to change. GM put the steel brake line in the way, plue thatfront diff blocks any access from underneith. Got it in eventually. Probably easyer if I undid both sides, but im stubbern.
From what I've been reading... You only unbolt one side at a time, however, you loosen the opposite side...
95Blazer4x4
02-01-2008 08:19 PM
