engine mountings
Old Aug 14, 2007 | 01:31 AM
AutoLAS's Avatar
AutoLAS is an unknown quantity at this point
Default engine mountings
Hello!
I tried to change all engine mountings (because they are really bad) on my chevy blazer 1999, 4,3 V6 , 4 wd.
I read that after some basical operations i should just lift up a little bit myengine and I will see the mountings. In special catalog I found that changing ofmountings takes only 2 or3hours. But I dont believe that it`s posible to take offengine with the transmissionand put them backfor only two or three hours.In any case, it`s not so easy as read.
Maybe somebody know how to do that (to change engine mountings)?
Maybe, I should do some special operations ... because now, I just lock on my engine and i dont know what to do.
Please, write how to do it step-by-step.
Thanks for all!
Old Aug 14, 2007 | 06:58 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: engine mountings
I change em one side at a time, just loosen up on the tranny mount bolt on the tranny x-member and you should gain the clearance you need.
N.alaska_blazer
Feb 23, 2009 01:31 PM
Tony H
Dec 14, 2008 02:04 AM
johinut
Oct 24, 2008 04:06 PM
loppy crimp
Sep 11, 2008 08:31 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
