Engine Noises
Been a few years since I was last here, so quick catch-up, my original engine bit the dust when the oil pump went out, so I dropped in a "new" engine and transmission that I bought from a friend. Had it going for about a year, now there is a strange bearing noise coming from either the engine or transmission only at idle and mostly when it's warm. It sounds similar to a dry, slightly worn bearing, but it goes away once you get it above 1000 rpm, and I hear it mainly inside the vehicle, below the dash area. The transmission seems to have a hard time deciding which gear it wants to be in on hard takeoffs from a dead stop, but is fine if I start off slow and then floor it. There is also a strange whistling noise that sounds like a mini jet engine shutting down immediately after I turn the engine off (possibly Spectre cold air intake?). I never had any of these noises on my old engine and transmission, need help cause I dont want to end up on the side of the road again.
bdscholes71`
Oct 7, 2007 02:59 PM
