engine problems
Old May 12, 2010 | 10:56 AM
problems's Avatar
problems is on a distinguished road
Default engine problems
hi.just went out to start my blazer,and she will not start.she turns over,but no go.this happened the other day to my wife.when i got in she started first try.if any one has a suggestion let me know.thanks.shes a 2000 s10 blazer LT WITH 177,000 KMS.DONT THINK ITS THE FUEL PUMP,BECAUSE I CAN HEAR IT BEFORE I TURN THE IGNITION.READ A FEW POSTS,AND THE SECURITY LIGHT DOES NOT COME ON.THANKS FOR ANY HELP OR ADVICE.
Last edited by problems; May 12, 2010 at 11:34 AM. Reason: LEFT OUT MAKE AND MODEL.
Old May 14, 2010 | 12:21 PM
hemivette's Avatar
hemivette is on a distinguished road
Check your "ignition control module" inside your distributer, you can take it out and have it tested at your local auto parts store. I've owned GMs all my life, and I always keep an extra in every rig, cause they can go out without warning. the last time it happend to me, I was on the freeway and I slapped a new one in, In about 5 minutes, and was on my way. If it is bad, dont cheap out on the parts, it sucks being stranded! Good Luck!
Old May 15, 2010 | 01:32 AM
4x4blazerguy's Avatar
Just because you hear the pump doesn't mean it is pumping the required 60 PSI. You need to check the fuel pressure. From everyone I have seen or heard if you can hear it, it is either BAD or GOING OUT.
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
recruiter
Jan 5, 2007 02:58 PM
md95
Apr 14, 2006 01:49 PM
BlaZinNaTe
Engine & Internal
Dec 29, 2005 05:38 AM
