Engine rings
Old Oct 28, 2020 | 08:59 PM
Xracing1's Avatar
Xracing1 is on a distinguished road
Default Engine rings
I was just wondering why people don’t use total seal rings in there turbo builds? I mean no boost loss and no ring land problems right?
Old Oct 30, 2020 | 03:55 AM
There are 120 years of engine building experience in the way we make things today.
Some of the problems to overcome with a closed ring:
How would you give the ring a pre-load and at the same time avoid them binding under heat expansion?
Not to mention how one would go about manufacturing such a piston i.e. fit the ring to the piston.
Ring land problems are usually caused by detonation.
You cannot make a turbo conversion on a non-turbo engine without taking great care on the innards.
Forged pistons for strength, more clearance for the greater thermal expansion, less compression against detonation, enough fuel not to get into a lean condition under boost.
Modern well tuned engines show no boost loss. If you get blow-by in such a setup the engine will be damaged in short time.
Old Oct 30, 2020 | 09:40 AM
I had Total Seal rings in my drag racing car years ago. It wasn't a turbo, but they worked great.
This will explain them a little better, error_401.
Old Oct 31, 2020 | 05:03 AM
Ah, oh, my bad - thanks TomA
OP was referring to a product...
... sorry, didn't get that.
There is a reason we keep the ring gaps, especially with forced induction. If you cannot bleed off blow by the top ring can start to flutter, because of the high pressure between the two top rings. One of the reasons why high performance pistons use the accumulator groove. Seems one of the reasons why Total Seal recommends only one of these rings.
Learnt something new.
Probable reason not to use such rings: Price and you have to gap an additional ring.
Additional consideration I would take: Heat resistance of the thinner material (might be the reason why TS recommends it as second ring). Wear between the two rings.
Old Oct 31, 2020 | 11:22 AM
As I mentioned, I ran them in a drag racing engine that was NOT driven on the street. So I can't comment on their long-term durability. And that was almost 30 years ago, so I imagine there have been some product improvements since then.
Melissa Keith Sechrist
Sep 3, 2019 10:20 AM
mtexplorer
Nov 27, 2014 03:14 PM
sixgunzx2
Nov 30, 2009 02:38 PM
ahawks47
Aug 1, 2008 03:00 PM
frank29
Mar 16, 2008 09:07 AM
