Engine shivering
Old Jul 20, 2020 | 08:21 AM
LesMyer's Avatar
I see... you want us to ascertain the problem over the Internet without you having to do anything more. Not likely. I'm out.
Old Jul 20, 2020 | 10:45 AM
Big_george's Avatar
Big_george is on a distinguished road
My friend i did what they said i should do and got them back with the result. What did i do wrong?
Donyou have a certain temper issues so you keep attacking me? Are you having a rough day sir?
Because if you are then i am sorry but i have nothing to do with your misjudgment.
Thanks
Old Jul 20, 2020 | 12:10 PM
LesMyer's Avatar
Thanks
Well sorry you feel that way! In my view I took the time to propose a serious diagnostic strategy and offered to help guide you - then you completely ignored it.
Old Jul 20, 2020 | 01:10 PM
LesMyer's Avatar
Sorry, I have been off the forum around the holiday. You will need a decent scan tool that will read Enhanced GM Powertrain PIDs. What are you using for a scan tool? I can recommend an appropriate inexpensive scan tool for Android or i-phone (about $35), but I need to know what year Blazer we are working on and what phone you have. You will need to have your own scanner. Is the SES light on? What is the code number. Does it return after clearing?
If the scanner and IAC code takes us nowhere you will need to do compression testing and fuel pressure testing.
Both static and dynamic compression per this link. https://support.alldata.com/article/...pression-tests
Fuel pressure per this link. https://blazerforum.com/forum/2nd-ge...eakdown-88305/
You can get loaner compression tester and fuel pressure tester through local auto parts store as needed.
Let me know when you have an appropriate scan tool and are ready to begin.
Here's something strange, my post quoted immediately above from 7/5/20 4:14 is not assigned a number. Should have been #6 but it's not. Maybe you were never able to see it?
Old Jul 20, 2020 | 03:11 PM
Big_george's Avatar
But sir i did follow what the kind guys suggested and some of the steps they suggested i already have done.
If there is anything extra to do i would do it i was just waiting for a feedback from one of you guys so i can proceed. Plus i don't recall you giving a "process" what you said translates into either listen to my mechanic and not waste ur time or listen to us and do a diagnostic with the question "what camp are you?"
So as far as i know i am here listening to you not the mechanic with no process i can follow to diagnose my car or fix it!
Old Jul 20, 2020 | 05:14 PM
LesMyer's Avatar
OK lets start again - please answer my 5 preliminary questions:
You will need a decent scan tool that will read Enhanced GM Powertrain PIDs. What are you using for a scan tool? I can recommend an appropriate inexpensive scan tool for Android or i-phone (about $35), but I need to know what year Blazer we are working on and what phone you have? You will need to have your own scanner. Is the SES light still on? What is the code number? Does it return immediately after clearing?
Old Aug 15, 2020 | 07:42 AM
Big_george's Avatar
Hello,
Sorry for the late reply but i was involved in a car accident and was fixing it.
Mine is a1995 blazer so I need an obd1 and honestly i could not find a decent one!
As for the code i don't remember it sorry as in a mechanic shop where they were using their tool. And yes it returns after a long ride when the engine gets really warm.
Thank you
Jburn516
Nov 3, 2019 09:37 AM
Naydog101
Nov 14, 2016 09:50 PM
SmartBrotha
Jan 1, 2014 08:17 PM
ESKYMOPACK
18
Apr 10, 2009 09:29 PM
vatoDETH
Dec 26, 2008 12:04 PM
