Engine smokes and stalls while idleing
Old May 30, 2011 | 12:00 PM
blazingtrails93's Avatar
blazingtrails93 is on a distinguished road
Unhappy Engine smokes and stalls while idleing
Just replaced my engine in my 93 gmc yukon (350 small block) ran fine for the first day i was driving it around, second day when ever i got to a stop light it would idle real low then if the light was long enough it would stall out if i didn't give it any gas. I just replaced my fuel pump and fuel filter about 2 months ago, along with my air filter. I don't think I have a vacuum leak because i can not hear any hissing. any suggestions? Thanks.
Old May 30, 2011 | 12:22 PM
Rottidog's Avatar
Still may have a leak. When it's cold it should have a higher idle, that's when I'd spray some carb cleaner or brake cleaner over the vacuum lines & see if the idle changes. If it does - there's your vacuum leak!
Old May 30, 2011 | 12:36 PM
oisinirish's Avatar
Does start right back up easily?
Old May 30, 2011 | 01:08 PM
yeah it starts back up without a problem i just gotta give er some gas so she doesn't stall out
Old May 30, 2011 | 01:26 PM
I tried the brake parts cleaner over the lines and nothing changed.
Old May 30, 2011 | 03:32 PM
oisinirish's Avatar
TBI right? Sounds like it's flooding itself to me. There's a way to check the spray pattern from the TBI. Temp sensor could be telling the ECM the engine is still cold and therefore causing a rich condition. Mass air flow could be diry/confused. Not sure if a faulty O2 sensor could cause this. The DIY section explains how to diagnose some of those.
Old May 30, 2011 | 04:06 PM
Yeah its tbi, and I'll check the temp sensor, I do not have a maf sensor, they started putting those in 1996 and up. I have a 93. I'll check the sensor though
Blake726
Aug 4, 2012 05:37 PM
corhey88
Jan 21, 2010 06:28 PM
jigalow43
Jun 13, 2007 08:55 PM
davtak
14
May 14, 2007 10:02 AM
pfanni
Jan 25, 2007 12:42 AM
