engine smokes
Old Jan 24, 2007 | 11:11 AM
pfanni's Avatar
pfanni is an unknown quantity at this point
Default engine smokes
Hi, I had a problem with misfire in my engine but we fixed this last week. Since then we recognized that there is white smoke everytime I switch off the engine.
The smoke appears behind the AC compressor and I have no idea what that might be. It smells a little bit like cooling liquid but I couldn't find a leak.
Could it be the AC itself which is leaking. Another problem which might go together with that, it's not heating anymore!!
Please give me some new ideas, I'm desperate.
Thanks
Matt
Old Jan 24, 2007 | 03:26 PM
20Blazer00's Avatar
Default RE: engine smokes
Heater core is taking a puke on you ..... you will have to remove the plastic from around the A/C and dissassemble the dash enough to get it out....also check coolant level in overflow and radiator when cool or cold...don't do this when hot or you could require plastic surgery for a new face....
Old Jan 24, 2007 | 08:43 PM
pfanni's Avatar
Thanks a lot, I'll try this!!
Matt
1997 Blazer, 4WD, V6
Old Jan 25, 2007 | 12:42 AM
Hanr3's Avatar
Which A/C are you tlaking about? Unde rthe hood or in the dash?
Yes, they are related. No heat becuase your low on anti-freeze. Check yourradiaotr and overflow tank for fluid. If this is behind the A/C unit under the hood. check your water pump and hoses for leaks. Look for a white or brownresidue.
blazingtrails93
May 30, 2011 04:06 PM
MetallicaFreak24
Nov 28, 2010 09:23 AM
corhey88
Jan 21, 2010 06:28 PM
N.alaska_blazer
Feb 23, 2009 01:31 PM
DBlaser_ca
Aug 2, 2007 04:44 PM
