engine swap for a 02 jimmy from a blazer
Old Aug 19, 2013 | 06:27 PM
elcoomagnifico's Avatar
elcoomagnifico is an unknown quantity at this point
Default engine swap for a 02 jimmy from a blazer
hey guys, i have an 02 jimmy with a blown enigne. i have been trying to look online for a different engine to swap it with. i ended up finding a 04 chevy blazer engine with 106k. my question is will this engine work in my jimmy if i swap it out?
Old Aug 19, 2013 | 10:55 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
it should
Old Aug 20, 2013 | 06:28 AM
Originally Posted by AndrewO1991
it should
thanks.. i didnt know if there would be something different with those engine since there are 2 years apart
anyone else before i buy it?
Old Aug 20, 2013 | 07:26 PM
roypai's Avatar
roypai is on a distinguished road
keep the '02 till you're done - IF anything it'll be a small detail and likely still working on the '02, just swap it over to the '04. The big bad parts that get blown like the heads, crank, pistons etc will be the same so you'll be fine there.
Old Aug 21, 2013 | 06:27 AM
coolasice's Avatar
coolasice will become famous soon enough
if yours does not have the egr system it is a direct swap, is it does then you will have to swap lower intake, exhaust manifolds and drill/tap knock sensor
Old Aug 22, 2013 | 07:11 PM
i know my jimmy has a vin w and the 2004 engine is a vin x
i have been reading online about this, and it seems like there is a couple things that are different. but sound like it is almost the same engine. sounds like it should swap easy
anyone swap to an x and have any problem that i should know about??
Jimmy man 4x4
Engine & Internal
Apr 4, 2012 08:50 PM
Mrfixit1599
Jan 16, 2012 02:05 PM
rob03
Sep 24, 2010 03:35 PM
LowLife
Jan 24, 2010 11:57 AM
gmoney30
Jan 22, 2010 07:07 PM
