Engine ticking! HELP!
Old Dec 10, 2007 | 11:14 AM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default Engine ticking! HELP!
I have a 96 4X4 Blazer 4.3 V6 I just started to notice that my motor is ticking everytime its at higher RPM, it ticks faster at high RPM, when it's in park it ticks slowly. whats the problem?
Old Dec 10, 2007 | 04:23 PM
drperry's Avatar
Default RE: Engine ticking! HELP!
Check your oil?
Could be valvetrain noise.
Old Dec 11, 2007 | 05:08 PM
Hanr3's Avatar
^ yep.
Depends on where the noise is coming from. Howver if it is in time with your engine rpms, typically its a valve. Like posted above, check your oil level and type.
You may need to run some seafoam through your oil system, although I prefer Marvelous Marvins Mystery Oil. Read the cans on each.
Old Dec 11, 2007 | 05:12 PM
Jharper's Avatar
it went already, oil pump is gone, rods are twisted, bearings gone, crank is gone. need new bottom end.
Old Dec 12, 2007 | 06:00 PM
Hanr3's Avatar
bummer.
I see you started a thread on a possible engine to replace it with.
94tahoe95lt
Aug 9, 2013 02:56 AM
alfred1254
Jan 11, 2010 02:01 PM
willtoskie
Jan 10, 2010 04:56 PM
coffeehound5150
Oct 3, 2008 05:56 PM
low
Jun 25, 2005 04:52 AM
