engine whining
Old Mar 6, 2007 | 05:42 PM
20Blazer00's Avatar
Default RE: engine whining
If you decide to do this procedure I would suggest that you start with a cold engine in the morning that will reduce any risk of over heating since the t-stat has not opened and the engine coolant would have to start from scratch. Since it takes the engine about 5min to warm up this would give you plenty of time to find out if the alternator/serp belt is your problem...
Old Mar 7, 2007 | 04:19 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
ORIGINAL: BlazerMan85
Codes would be your least worry, it'll overheat cause the water pump won't be spinning...
Seeing as a cold engine takes a good 3 to 5 min to warm up and this process takes less then 1 min, overheating is the least of the issues.
Sheesh who would let their truck run for more then 3 min like this?
Old Mar 7, 2007 | 06:15 PM
drperry's Avatar
Hopefully he doesn't have to drive far for the noise to kick in, as it only happens when he's in gear, it appears, lol
MissTina0301
Dec 18, 2010 03:17 PM
99whiteblazer
Jan 18, 2007 10:04 PM
smh7890
Jul 28, 2006 08:46 PM
skinny pimp gator
Jun 20, 2005 02:23 AM
tango1112
Jun 15, 2005 07:11 PM
