Engine won't start, help please!
Old Feb 22, 2011 | 09:19 PM
korreyk's Avatar
korreyk is on a distinguished road
Default Engine won't start, help please!
Hey guys, I am getting my butt kicked by my '02 blazer. I have had this truck since the start and have maintained it well. Last week, started noticing that under heavy accelerations, truck would hesitate. If I stepped on the gas too hard, I could get it to stall. The problem was intermittent and Saturday, she ran great. On Sunday, it wouldn't start at all. I checked for spark, had a spark on all 6 cylinders. Checked gas and had 55psi on the rail and it dropped right after prime. I replaced the fuel pump (GM mechanic told me I had to have at least 60 psi) with no luck. I have checked timing between crankshaft and rotor, it is OK (at TDC, rotor points to #1). Engine turns over, but won't start. Occasionally, it will backfire after cranking. The security light is not blinking while cranking, but the CEL is on during cranking. Any pointers would be much appreciated. Thanks!
Old Feb 24, 2011 | 05:42 AM
korreyk's Avatar
Replaced the distributor and rotor and it started right up. No visible damage to either.
doccheese
Dec 12, 2014 03:43 PM
Luvthyblazer
Apr 19, 2010 07:59 PM
terry s
18
Sep 20, 2009 10:36 AM
kwest3208
May 3, 2008 02:00 PM
christyleigh24
Apr 1, 2008 09:23 PM
