EVAP service port question
Old Jan 27, 2009 | 01:20 AM
daniel010's Avatar
daniel010 is an unknown quantity at this point
Default EVAP service port question
put a new motor in my truck and the EVAP service port line that goes into the intake was bent soo my buddy cut it and re installed it but he cut the green cap thing off does this make a difference can the cause anything to run crappy
Old Jan 27, 2009 | 09:04 AM
Default RE: EVAP service port question
The service port is just there to provide a place to check the system. You just need to make sure that the repair job your buddy did sealed things up appropriately.
Old Jan 27, 2009 | 12:04 PM
daniel010's Avatar
oh ok thnks if its not sealed proper could it make the truck run ****ty
Old Jan 27, 2009 | 12:07 PM
It is part of the vacuum system which, if leaking, would allow unmetered air into the intake, causing some difficulties.
Old Jan 27, 2009 | 12:49 PM
daniel010's Avatar
oh ok thanks alot i will put the other stock non cut one back on thanks for you time
ned4spd8874
14
Feb 16, 2016 03:58 PM
cpesko
Jul 26, 2013 02:33 PM
volfan4
Mar 21, 2012 08:42 PM
dj00140
Mar 14, 2011 09:51 PM
Indianarocker
May 18, 2009 04:42 PM
