firing order
Old Apr 1, 2007 | 10:34 PM
bigt's Avatar
bigt is an unknown quantity at this point
Default firing order
I have a 1984 2.8 v6 4 x 4 that is carburated. On the distributor cap I know where number 1 piston fires from and that it turns clockwise does the wires follow suit with the next one going clockwise number 2, 3, 4, 5, and 6? Also does anybody know what size the water pump bolts are? I am missing the bottom two on the right side and what size the bolts are that hold the alternator bracket to the head? Thanks!
Old Apr 2, 2007 | 12:15 AM
Hanr3's Avatar
Default RE: firing order
I believe the firing order is 1,6,5,4,3,2.
Not sure about the bolts. You may ahve to call the dealer and get the right ones.
Old Apr 2, 2007 | 10:41 AM
bigt's Avatar
Is it then 1, 6, 5, 4, 3, 2 on the distributor cap in a clockwise order? Thanks
Old Apr 2, 2007 | 10:48 AM
Per Autozone.com under Repair Info:
Code:
Firing order 1-2-3-4-5-6                     -------
                                      front  | 1 3 5 |
                                        of   |       |
 Distributor rotates clockwise       vehicle | 2 4 6 |
Old Apr 2, 2007 | 10:37 PM
bigt's Avatar
Thanks!
Old Apr 3, 2007 | 02:34 AM
Hanr3's Avatar
Thanks for the correction Kyle.
jerseyjim
Engine & Internal
Jan 17, 2007 12:14 AM
Dj7763
Jan 10, 2007 06:03 PM
USMaverick101
Oct 20, 2006 06:46 PM
tesshin
Sep 11, 2006 10:05 PM
Rahmir
Aug 16, 2005 12:52 PM
