float float float?????
Old Nov 20, 2008 | 10:33 AM
AJBert's Avatar
Default RE: float float float?????
Its not actually the float that gets stuck but the needle valve that the float controls. If you can somehow drain the gas out of the bowl and try 'tapping' the bowl, that might get the needle valve unstuck. I am not familiar with your exact carb but I do know them in general, so I can't tell you whether or not you can remove just the bowl while the carb is in place.
Old Nov 20, 2008 | 11:00 PM
rogggg1020's Avatar
rogggg1020 is an unknown quantity at this point
its the 2se carb rochester varajet,if that helps,,is there not a way to slide my finger in the front or back bbl to try to move the needle cause im not smelling any fuel out of the carb????
Old Nov 21, 2008 | 07:00 AM
Yield much information a quick google search does:
Rochester 2SE Exploded View - Carburetor Factory
Rochester 2SE/E2SE Guide - epnet
Rochester 2SE Adjustments - Autozone
Xk49
Mar 29, 2012 06:09 PM
Mulisha
Mar 24, 2008 09:14 PM
ytsurkytsur
Jun 23, 2006 08:33 PM
