Fuel inside intake manifold 95 4.3 CPI ??????
Old Feb 7, 2008 | 08:33 PM
95Blazer4x4's Avatar
95Blazer4x4 is an unknown quantity at this point
Default Fuel inside intake manifold 95 4.3 CPI ??????
Ok, so i started taking my new engine apart, so i can drop it in my blazer, i've taken all the accsessories off, and now the upper intake manifold is off, but i found fuel inside of it... the truck it came from had 100k miles on it and was said to run great before the accident, but i'm sure the fuel in the intake manifold is not normal, anyone have any ideas?
Old Feb 7, 2008 | 08:38 PM
Default RE: Fuel inside intake manifold 95 4.3 CPI ??????
Blown fuel pressure regulator is the most likely cause.
Old Feb 7, 2008 | 08:52 PM
i havent gotten to tear into my old motor yet, but assuming when i pull the upper off the old motor, and its not leaking would i be able to reuse it?
Old Feb 7, 2008 | 09:06 PM
I dont know if this is the answer to my question or not, but this is deffinatly what my manifodl looks like inside, and hope fully this helps somone else
http://www.asashop.org/autoinc/feb2000/techtotech.htm
Old Feb 8, 2008 | 03:09 AM
kerander's Avatar
kerander is an unknown quantity at this point
Well you need to determine where that leak is coming from for sure. If it looks like the pic, then it's probably the FPR, as swartlkk indicated. Remove the upper intake and pressurize the system. Of course if you have another one that works fine, you could use that, whatever "it" is. You can check out my DIY article on this for some more info.
prbjeepin
Apr 8, 2013 10:14 PM
Klturi421
13
Mar 19, 2013 07:19 PM
bigdaddykane93
Jan 14, 2010 06:56 AM
bigdaddykane93
Nov 18, 2009 09:57 AM
buccaru
Dec 22, 2008 09:27 AM
