Fuel Leak after fill up
After filling up (without topping off), my 96 blazer leaks some gas. After it leaks for a little while, it doesn't leak anymore.
I'm also getting a PO440 code, not sure if this is related or not.
I changed the fuel pump about 2 years ago, so I'm thinking (hoping) it's something else.
Any ideas?
Thx,
Fredgie
Any ideas?
Thx,
Fredgie
You did not happen to crack the valve at the front of the fuel tank when you replaced the pump did you?
Have a look around the fuel tank with a mirror to see if you can locate the leak.
The P0440 code is likely caused by your leak.
Mykel99
Apr 9, 2011 12:34 AM
Debbie
Jan 27, 2010 07:42 AM
dgastone
Sep 29, 2008 10:17 AM
