Fuel Leak after fill up
Old Mar 26, 2009 | 04:35 PM
fredgie7's Avatar
fredgie7 is on a distinguished road
Default Fuel Leak after fill up
After filling up (without topping off), my 96 blazer leaks some gas. After it leaks for a little while, it doesn't leak anymore.
I'm also getting a PO440 code, not sure if this is related or not.
I changed the fuel pump about 2 years ago, so I'm thinking (hoping) it's something else.
Any ideas?
Thx,
Fredgie
Old Mar 26, 2009 | 05:03 PM
rriddle3's Avatar
Leaks how much - a few drops, a cup full? Have you tried to see where the leak is coming from? It may be somewhere along the filler neck.
Old Mar 26, 2009 | 05:06 PM
You did not happen to crack the valve at the front of the fuel tank when you replaced the pump did you?
Have a look around the fuel tank with a mirror to see if you can locate the leak.
The P0440 code is likely caused by your leak.
Old Mar 27, 2009 | 11:27 AM
fredgie7's Avatar
thanks for the quick responses, fellas.
if i let the pump fill up the tank until it automatically stops pumping, then a ton of gas spills out from somewhere by the tank.
coolcat0285
Oct 29, 2012 10:18 AM
Mykel99
Apr 9, 2011 12:34 AM
Debbie
Jan 27, 2010 07:42 AM
mikegav
Nov 3, 2009 11:21 AM
dgastone
Sep 29, 2008 10:17 AM
