tranny slip after over fill
Old Oct 22, 2012 | 08:15 PM
coolcat0285's Avatar
coolcat0285 is on a distinguished road
Default tranny slip after over fill
ok folks hope you can help? i bought an 89 chevy blazer last week about 50 miles from my house drove just fine on the highway and all but then a relaative thouhgt the the tranny fluid was low so they added more well it worked just fine for awhile but then drive and overdrive started slipping well i drained some out but to no avail. so i did the filter and fluid change plus a bottle of lucas tranny fix same thing so i added one more bottle now it will grab drive and overdrive starting out but once it gets to a certain speed or rpm they both slip what can i do ? it seems once it hits 35 they slip but put on the brakes and bring it back down to 20 they catch again ...
Old Oct 23, 2012 | 03:18 PM
grizzstang's Avatar
grizzstang is on a distinguished road
Having your trans a little over full will not make it slip to my knowledge. I suspect the trans was toast when you bought it and a band aid was added to make it work until it was sold. Anything unusual in the pan when you dropped it?
Old Oct 25, 2012 | 10:58 AM
no nothing out of the ordinary. but a few small plastic chunks from the filer tube ring that stops the tube from going too far in, also the fluid was almost black and smelt burnt really bad.
Old Oct 25, 2012 | 11:32 AM
richphotos's Avatar
Fluid like that= trans toast.
Old Oct 25, 2012 | 11:51 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Agreed
Burnt/black fluid = toasted trans.
Now you have to decide is your jimmy in good enough condtion that its going to worth replacing it either used or rebuild.
Old Oct 29, 2012 | 10:15 AM
ok so if i'm going to replace the tranny i'm pretty sure it's an 700/r4 but would like someone with more knowledge to confirm that so i don't get the wrong tranny. thanks Details - 89 blazer 4x4 4.3 L vortec v6
Old Oct 29, 2012 | 10:18 AM
chris015's Avatar
I replied in your other thread. if yours is black/burnt,time to replace for sure.
Mykel99
Apr 9, 2011 12:34 AM
badpoor
Jan 7, 2011 06:35 PM
Debbie
Jan 27, 2010 07:42 AM
fredgie7
Mar 27, 2009 11:27 AM
Aquahallic
Mar 23, 2008 01:55 PM
