Fuel Pressure Bleed Causing Rough Start
Old Oct 31, 2024 | 02:03 PM
GeorgeLG's Avatar
Originally Posted by Wyattblazer
So I went out this morning and primed the pump about 4 times before trying to start it. It cranked for about 4 seconds before sputtering to life. So either then its the spider still leaking into the intake and flooding it or it isn’t fuel at all correct?
you have to go back to the fuel pressure test and if it fails, check the fuel filter to confirm whether it’s in the tank or in the Plenum. If it’s in the Plenum, then you need to open it up. If it’s not a fuel pressure issue then it’s likely ignition, timing or fuel quality.
George
vetplus40
Jun 4, 2018 11:41 AM
Davecubs14
50
Aug 29, 2015 05:44 PM
iammsp
Jan 9, 2013 12:30 PM
blueblazer1982
Jan 7, 2012 07:19 PM
BlazerRJM
22
Dec 4, 2006 04:20 PM
