Fuel pump
Old Dec 1, 2007 | 08:42 AM
Irongutz's Avatar
Irongutz is an unknown quantity at this point
Default Fuel pump
[align=left]I recently replaced my fuel pump and the truck still would not start. I had 55 psi at the test port. After checking all fuel lines and replacing the filter I replaced the fuel meter body and injectors. When I put everything back together I suddenly have no response from the fuel pump. I have replaced the realy and still nothing. My Hayne's Guide mentions a fuel pump test terminal but I can't find it. It say that it's located in the drivers side corner of the engine cvompartment but I don't see it. Thanks in advance
[/align]
Old Dec 1, 2007 | 12:03 PM
Chevy Lover's Avatar
Default RE: Fuel pump
Vehicle info?
There should be a loose green wire close to the fuel pump relay which is the fuel pump prime.
Old Dec 1, 2007 | 03:10 PM
Hanr3's Avatar
I thought it was a red wire over the brake booster next to teh firewall? It may be hiding in that wiring harness.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
