fuel pump bad again? 95 blazer s10
Old Feb 2, 2012 | 08:55 AM
potterymike's Avatar
potterymike is on a distinguished road
Default fuel pump bad again? 95 blazer s10
I replaced the fuel pump that was bad in my 95 s10 blazer 3 months ago. I used a spectra fuel pump from advanced auto, is it just odd that this happened or could there be something making the fuel pumps go bad? Any ideas
Old Feb 2, 2012 | 11:41 AM
Thogert's Avatar
It's probably the brand you used. These blazers only like ACdelco and delphi pumps.
Old Feb 2, 2012 | 01:36 PM
chris015's Avatar
^^werd.
oem pumps only for these. even if the sales guy says they're brands equivalent.
Old Feb 2, 2012 | 02:11 PM
xgiovannix12's Avatar
X3 OEM pumps only
go with aftermarket you snooze you loose be prepared to drop the tank in the future
any ways id start diagnosing the fuel system DO you hear the pump ? if you do follow the link im giving you
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
Old Feb 2, 2012 | 03:08 PM
pettyfog's Avatar
Mike, nothing personal but you joined this site in June.
What were you reading on here all that time? The fuel pump is in the top three subjects of all systems threads. And every thread says the same thing.
AC Delco or Delphi
However you should do the diagnosis.. there's other reasons.
Old Feb 3, 2012 | 06:58 AM
there is no noise at the pump, i know for sure it is not running. next i'm checking for voltage at the pump, if i do not have voltage what should i look for?
Old Feb 3, 2012 | 09:04 AM
check the ecm b fuse and the relay
Old Feb 3, 2012 | 10:01 AM
checked the fuse and if it is the relay in the glove box i checked it also
Old Feb 3, 2012 | 10:06 AM
i did read the threads and thought i might get lucky, looks like saving a buck has bit me in the butt. thanks for the diagnosis link
Old Feb 3, 2012 | 03:48 PM
do you have power to the pump harness?
