fuel pump bad again? 95 blazer s10
Old Feb 3, 2012 | 05:25 PM
potterymike's Avatar
potterymike is on a distinguished road
that is what i have too check next i have too wait for a break from work and the rain, if i have no power what should i look at? thanks for the help!
Old Feb 3, 2012 | 05:35 PM
xgiovannix12's Avatar
fuse and relay
try swapping relays and see if she kicks on
if she dont start tracing the wires under the truck
war00's Avatar
war00 is on a distinguished road
if you have no power than i would check to make sure the relay is getting 12v and putting out 12v when switched on you can also jump the relay and supply the pump with 12v.
Old Feb 3, 2012 | 09:39 PM
chris015's Avatar
yep,ONLY for testing purposes you can take a paperclip,and remove the relay,and cross each connection until you find the 2 that provides the 12 volts straight to the pump. if its the relay thats bad the pump will kick on,then remove the clip.
Dont do it when the filters off and you have friend underneath it with a cigar lit looking for broken wires...
Dont ask LOL
spittybays
Nov 3, 2012 04:12 PM
gatelocked
Feb 28, 2011 04:52 PM
KRUSHER
Jan 2, 2010 07:25 PM
ndekens
Apr 4, 2009 03:50 PM
2drblazer
Jun 25, 2008 06:03 PM
