fuel pump or level sender?
Old Mar 24, 2007 | 07:31 PM
scottyk's Avatar
scottyk is an unknown quantity at this point
Default fuel pump or level sender?
I am getting low fuel pressur.
I alredy installed a new fuel filter.
So it has to be either the fuel pump or level sender, right?
Is it any other possibility it could be?
Old Mar 24, 2007 | 07:45 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: fuel pump or level sender?
Is youe Blazer fuel injected or is it an older model carbuerated?
If its injected, It could be the sending unit, but if there is low pressure and the is no leak, it is definately is the fuel pump. I believe your problem is that the pump is losing pressure somehow.
I have a fuel pump problem myself, it seems to make a loud grinding noise, but I haven't lost fuel pressure at all. Seems a bit weird.
Old Mar 24, 2007 | 08:58 PM
Lee's Avatar
Lee
Lee is an unknown quantity at this point
I work with fuel systems on aircraft and usually when we get low fuel pressure it's the pump. I know it's two different worlds, but the principle is the same.
Old Mar 24, 2007 | 10:26 PM
20Blazer00's Avatar
It could be fuel pressure regulator located in the fuel meter block (fuel injection spider), some are replaceable. A good way to tell is the smell of raw gas in the intake manifold. Although this could also be a meter block leaking but it will let you know if the problem is in the upper intake...
Old Mar 24, 2007 | 10:32 PM
Chevy Lover's Avatar
What year is your truck and what is your fuel pressure reading?
Old Mar 24, 2007 | 10:54 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
I don't think it matters what year your truck is, if it has low fuel pressure, it is NOT being caused by a bad sending unit! The sending unit is strickly used to indicate how much fuel is in the tank. It has nothing to do with pressure. Like chevylover said we need to know your pressure reading in PSI and the year/model/engine etc.....to help you diagnose this ACCURATELY.
Old Mar 25, 2007 | 12:38 AM
4lowlife's Avatar
I would change the fuel pressure reg as 20Blazer00 stated.
My pump has been unusually noisy lately. I have good startups, but the audacity is is concerning me.
Old Mar 25, 2007 | 09:19 PM
Lee's Avatar
Lee
Yeah, anything used for indication is not going to have an effect on the gas moving through the system. There's nothing mechanical to them anyways.
Kainon
Dec 13, 2010 11:27 AM
ty.justin
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jan 10, 2010 06:37 PM
doodad69
Jul 4, 2009 10:14 AM
evlblkwpnz
Sep 17, 2008 09:46 PM
MCas86
Apr 25, 2006 02:59 AM
