Fuel pump problem
You should be able to exchange the pump. If you can drop the tank just a bit to be able to get at the wiring connector, then back probe the main power wires, reconnect the connector and tighten the tank back up, then you would have probes in and ready to test power directly at the pump to see what it is doing.
As an aside, in the future, if you have a need to ask more questions within say 24 hours of your last post and another member has yet to respond, please use the edit feature to add your questions/information to your previous post rather than posting again.
Okay update... My truck was working fine today. Left the house to get gas and food the truck died once in the gas station i smacked the fuse box and the pcm and it started right up, filled up and went to get food and it died again. This time i smacked just the pcm and it started right up. Just a few seconds later it died again. And now all the smacks in the world won't start it. But one thing i noticed that was strange when the truck was turned all the way off the fuel gauge was at empty then started to move up to half full. Thought that was strange with the truck shut off
Man, even though you are not seeing the security light come on, I would really suspect the ignition switch. It is not all that expensive and is fairly straight forward to swap out.
Update...
Well i rip everything apart again to test the wires, pcm, and the new fuel pump. Well i took the connecters off the fuse box to test the wires going back to the fuel pump. And i noticed the grey wire in connecter 3 pin 7 was black and burntand the outside of the connecter was burnt itself. This i believe would explain why the truck starts up after smacking the fuse box.I haven't bought the part yet but i'm 99% sure this is my problem. Thanks for everything buddy you look to be a busy man on this site so i appreciate your time and ideas i will update again to let you know if this fixes my problem. And hopefully i make it to S.C. this weekend.
That would do it. I have seen this a few times, but not enough to say it is a common problem. This could be caused by someone taking things apart at some point and something getting in there, disrupting the connection.
Anyway, fix that and I am sure that you will be on your way.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
mytruck2
Dec 13, 2006 04:50 PM
