Fuel Pump Problem
Old Mar 14, 2010 | 07:38 PM
jashingu2's Avatar
jashingu2 is an unknown quantity at this point
Default Fuel Pump Problem
well about a week ago my blazer just dies, its a 96 4dr 4x4, had it towed home and replaced the fule pump and now its getting no power at the pump. I traced the wires into the engine compartment it has power there. The fuse is good. Im thinking that maby the wires got cut or somthing. Before i go running new wires i was woundering if theres anything obvious that im overlooking?
Old Mar 14, 2010 | 10:19 PM
blazendizz's Avatar
blazendizz is on a distinguished road
is relay good? is wireing harness hooked up? is the wire plugged into the pump the right way or all the way? it could just be a ground i know on my s10 i had the ground was hooked up wrong thats all that was wrong with her
Old Mar 15, 2010 | 04:10 PM
jashingu2's Avatar
relays good, and it plugged into the pump, mechanic seems to think its an oil pressure switch anyone know if this could cause it, i know iv had low oil pressure recently.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
