Fuel pump or Relay?
Old Nov 4, 2007 | 11:19 AM
ChooChooBlazer's Avatar
ChooChooBlazer is an unknown quantity at this point
Default Fuel pump or Relay?
Hi guys! Been using the forum for a while, but now it's time for a first post
My '87 Blazer (2.8l) S-10 Tahoe died last week
Fuel problems: no fuel coming into the carbs. So I took off the hose supplying fuel, sucked out air then gas, then lots of gas... so no blockage there. Firing it up again, there's no gas coming out the hose. So no pumping. Problem is, it could be simple like the relay or more serious like the pumps gone
I don't know where the relay is for this... anyone know?
I know I could test the pump by running a live to it, but it's a lot of work to test, dropping out the tank etc if it might just be the relay
I'm pulling my hair out here and being located in the UK, don't know anyone locally who knows about 80's Chevys
Any advice welcomed massively!
Old Nov 4, 2007 | 11:32 AM
hillbillyinOhio's Avatar
Default RE: Fuel pump or Relay?
i believe the fuel relays are on the firewall, pass side rear of engine.
Old Nov 4, 2007 | 11:36 AM
Thanks I also just realised, not sure if it has an electric or mechanical pump... is there a quick way to check?
Tony H
Apr 16, 2014 08:36 PM
upblazer95
Mar 8, 2009 07:15 PM
bestes
May 31, 2008 03:16 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
