fuel return line plastic nozzle???
So I replaced three fuel lines on my 00 blazer yesterday and when going to put the tank back in I accidently cracked the plastic nozzle that the return line goes into the tank at. Its at the opposite end of the the fuel pump on top of the tank. Do parts stores carry this? or is there a special adhesive i can put on it or some plastic welding. I would like to just replace it. Need help.
2000 Blazer 4dr 4wd 202k
Did you break the hard plastic return line? Or the nipple on the fuel pump itself. I broke the hard plastic line, and a replacement is $50.
I am looking at similar QDs to see if something can be correctly fanned to fix this problem.
scphill34
May 30, 2013 10:20 PM
billfrank85
May 5, 2013 02:07 AM
AbbyNormal
Mar 25, 2013 08:27 AM
hevi99
Aug 7, 2011 09:10 PM
