Gas smell in cab of truck
Old May 15, 2018 | 03:01 PM
SPIKE318's Avatar
SPIKE318 is on a distinguished road
Default Gas smell in cab of truck
I have a 96 S10 extended cab 4.3 Vortec V6 I am getting a strong smell of gas inside the cab of my truck. Truck is running great except for the smell of gas. Only had one trouble code and it was intermittent code for the right Bank O2 sensor. Can anyone give me an idea where to look to address this problem? Everything I have read is pointing to the fuel pressure regulator but I don't want to spend money I don't have to if that's not the problem. Any suggestions would be very helpful, Spike 318
Old May 15, 2018 | 04:55 PM
From what I've picked up here, one of the first checks to do is measure the pressure in the fuel lines. The gauges for doing so can be borrowed from autoparts stores. Look for threads as to how long the system should be able to stay pressurized at at what pressures.
Old May 15, 2018 | 04:57 PM
SPIKE318's Avatar
Thank you I'll get me a gauge and check it
Old May 15, 2018 | 05:30 PM
rockp2's Avatar
See the link in the bottom of my signature block to do the fuel pressure/leakdown test Christine is referring to. Follow Captain Hook's instructions.
Old May 15, 2018 | 06:31 PM
SPIKE318's Avatar
I guess I'm stupid I don't see that link
Old May 15, 2018 | 06:41 PM
rockp2's Avatar
It's at the very bottom of my post.
Old May 15, 2018 | 06:43 PM
SPIKE318's Avatar
I was on my tablet when I responded I log into my desktop and was able to see the post thank you though
Old May 16, 2018 | 08:31 AM
LesMyer's Avatar
Since you are already suspecting the fuel pressure regulator, let me tell you that the 60-66psi fuel pressure spec with KOEO in Captain Hook's post is definitely not hard and fast. In fact, many replacement injection spiders regulate to 58psi with the engine not running (including the AC Delco). So if you get 58 psi, don't say the regulator is bad because of the pressure. Also, know that replacement spiders are MPFI and do not require a minimum pressure to "pop off" and deliver fuel. The rest of Captain Hook's procedure is golden.
86K5Silverado
Mar 24, 2015 08:15 PM
richphotos
Aug 5, 2013 01:23 PM
afferable1
Jul 26, 2012 07:17 PM
butters
Oct 27, 2010 05:27 PM
trapperjohn4077
Jun 7, 2010 10:49 AM
