gas tank removal
Old Dec 7, 2007 | 10:06 AM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default gas tank removal
can som1 tell me how to remove this thing please??? after a half tank it just pours out
[/align]
Old Dec 7, 2007 | 10:52 AM
Default RE: gas tank removal
Pull the straps with the tank supported. Lower a bit to gain access to the lines, then lower out of the way.
Old Dec 7, 2007 | 11:39 AM
Banned
is it hard??? any pics to do it???
[/align]
Old Dec 7, 2007 | 11:59 AM
Banned
how do you remove the straps
[/align]
Old Dec 7, 2007 | 01:15 PM
Chevy Lover's Avatar
[ol]Loosen the filler neck hose clamp at the fuel tank.
Disconnect the fuel tank filler neck from the fuel tank.
Support the fuel tank with a piece of wood on a jack
Remove the fuel tank shield. 4 bolts.
Remove the tank straps. 2 bolts
Lower the fuel tank..slowly. Best to have help to steady the tank and watch for any hoses getting caught up.
Disconnect the fuel and vapor hoses and the electrical connections at the sender
[/ol]
[IMG]local://upfiles/2910/A792E66035E44DABA28F9BA0C97FEE64.gif[/IMG]
Old Dec 7, 2007 | 06:20 PM
Hanr3's Avatar
Gas weighs roughly 8 pounds per gallon and figure on 20 pounds for the tank.
10 gallons of gas is roughly 80 pounds plus a 20 pound tank. That's 100 pounds, if oyu cant bench it with one arm use a jack.
Old Dec 8, 2007 | 10:53 PM
Banned
if it was on a scale of 1-10 how hard would this be?
[/align]
Old Jan 2, 2008 | 10:17 AM
Sorry it has taken so long to reply... As far as a 1-10 scale (10 being the most difficult), I'd probably put this at a 6 due to the awkwardness and definite possibility of hitting corroded fittings. The key is cleanliness and support. If possible, after dropping the tank a few inches support it on some jack stands while you disconnect the various electrical, fuel, and vapor lines.
Old Jan 2, 2008 | 04:59 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
be carefull removing the gas tank if u have the metal tank u'll see a vent valve in the front of the tank on top, the hose to it is too short and when u lower the tank and u havent release that hose the valve will break so i recomend taking that hose off first the valve is like $22 in the dealership good luck
Old Jan 2, 2008 | 08:40 PM
96Ls4Dr's Avatar
96Ls4Dr is an unknown quantity at this point
ORIGINAL: felonyblazer96
Do you mean when you fill up? Could your gauge be wrong and you really only need a half tank not to fill up?
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
blbikerood
Jan 21, 2010 09:00 PM
degaine_designs
Aug 19, 2009 11:12 PM
SnowRemorse
Jan 4, 2008 11:26 AM
