gear shifter indicator light out
Old Nov 8, 2009 | 05:56 PM
dolphin1's Avatar
dolphin1 is on a distinguished road
Default gear shifter indicator light out
I just had a reman engine installed in my 2000 blazer. Now the position light on my cluster that shows what gear I am in no longer lights up. All other indicators and lights work fine.
Could this just simply be an electrical connection issue w/ the tranny?
Any help would be appreciated.
Old Nov 8, 2009 | 06:02 PM
This likely is not a fault of the transmission connections. This is typically a problem with the cluster itself. If you remove the cluster, take a look at the solder joints on the back side of the circuit board. These joints have been known to crack and cause the issues you are experiencing.
Old Nov 8, 2009 | 07:24 PM
dolphin1's Avatar
Thanks for your quick response.
Honestly, I doubt I'll be tearing my dash apart for this one. This must just be an unfortunate coincidence, because it was working before the engine was installed.
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
rbcar1
Dec 13, 2009 10:20 AM
kthdwn
Nov 7, 2009 11:36 PM
PiTRiFF
Feb 13, 2009 04:31 PM
